Question for the guys that have the bottle in the back seat.
Old 04-16-2010, 05:25 PM
01trans am's Avatar
Default Question for the guys that have the bottle in the back seat.
Alright guys I'm fixing to get the tranny hump mount for the TA from HSW. The only thing I have been wondering is how are yall running the lines? Do you drill a hole and run it up the hump into the engine compartment or run it through the car? Give me some ideas here this is the only thing I'm not sure of and I'm fixing to get the HSW plate kit next week
Old 04-16-2010, 06:20 PM
OIF1VET's Avatar
Mine runs under the car..
Old 04-16-2010, 10:15 PM
Twotonefreak's Avatar
Mine is run under the car, passenger side. I ran it up thru the rubber grommet under the seat.
Old 04-16-2010, 10:35 PM
Doobie52's Avatar
I ran mine up under the carpet under and then through a hole in my firewall in my HVAC blockoff plate.
Old 04-19-2010, 09:33 AM
YURVIEW's Avatar
Ran mine in the car. Under the passenger side rear seat, then Under the passenger side plastic kick panel then thru a hole In my firewall under the passenger side dash.
Old 04-19-2010, 10:39 AM
Nick@HSW's Avatar
There is a grommet under the rear seats. 1 on each side. Just pull the bottom cushion out by removing the 1 bolt. You might be able to lift the carpet up slightly to expose the grommet. Carefully make a small x into it with a box cutter and slip the hose through.
Nick
Old 04-19-2010, 11:18 AM
01trans am's Avatar
Thanks guys thats what I needed to know.
Nick you should be hearing from me sometime this week. Have to make sure I have enough funds to get everything
