Hit the lil red button and see smoke in the rear view
So today i switched to the Nitrous Express plate kit from my dynotune single nozzle. i still run the dynotune solenoids, just got a deal on the maf kit, ne way i get the 150 pills in cause thats what was in there b4, and go for a spin i get the bottle to a tad over 900, purge and spray it. I immediately notice smoke in my rear view i stay on it for a good 7 seconds all together and dont try it ne more.
I never noticed this with just the single nozzle kit is there something i should change? i did the test run in 4th gear ne input will be greatly appreciated thanks
No nothing at all, i just put it in and sprayed it, im going to next time i go out with the tuner, im going to get his opinion on it, im curious tho as i had to switch to the Nitrous express pills instead of using my Dynotune pills maybe that has some factor in the situation.
Was the smoke white, black, or blue? If its white its way lean and if its black its pig rich and if its blue its time for a rebuild. You better call Nitrous Express and get the proper jets in there! Also what plugs and timming are you running?
Then it was way lean cuz it was white smoke, I sprayed it again today just to double check it and there was hardly no smoke, maybe it was cuz I hadn't sprayed the car in a while... I'm running tr6 plugs but going to switch to the bre7s whatever they are called. I'm running 25 degrees of timing now but got an lnc002 on the way so will add more timing for na runs. Oh and I got the right jets already
and do you know what jets were in it when you sprayed it? actual jet number nitrous and fuel?
