Timing for 150 nitrous (table pic)
How does it look
Im shooting 150, vp on a dedicated at 6 psi, autolite 103, AFR I guess it will be around 12 since Im still figuring out where to settle for a safe start, using microedge to control shot, this is a base start since Ill make change on what plugs says
stock table
all inputs are welcome
stock table
Smooth the timing in so its a smoother transition going from 2400 to 3200, imo. Also thats a but load of timing in the upper rpm/lower kpa tables (no load zone) do you have any knock at all?
