How Much Spray On an Lq4???
I am planning on doing a 414c.i lq4 how much do you think i can reliably spray with a good rotating assembly ??? I have heard guys with 408's spraying 300 shots can i do the same with the lq4? Lmk what you guys think thnx, Mike
with a good stout bottom end a 300 should be no problem. i am in the process of my 408 build. i have 13.3 to 1 c/r, callies crank, callies rods and custom diamond nitrous pistons with a set of total seal rings. Diamond told me i should have no problem hitting these pistons with a 500 shot of juice. but with even a 300. its ll in how you feed it to the motor for reliablity and longivity. this amout your going to want to progressive the system and possibly put it on 2 stages. are these a must NO. but will ensure exactly how much your feeding the motor.
Idc what cubic inch motor is in it, depends on what piston and ring pack is in it. Most off the shelf stuff wont handle that 350-400 etc shots.
and just because your motor builder says it will take 300 or more, good luck on the tune and I hope you know what you are doing.
Maybe I am miss-understanding you but you won't want to spray 300 on a plate. You are going to need direct port for 300 plus. I havn't heard anyone reccomending over 250 on a plate because you will lean cyl #7 I think it is really quick and destroy the motor.
Ok thx for the help guys im trying to do this on a budget so any place i can save money is very useful. Uhm camscam02 you seem like u know ur shytt when it comes to this will i be able to use the l92 head with this amount of spray i heard that the head might lift and leak water is this true???
I know a little bit. haha. Depends on what you are trying to do, yes the deck on the l92s are thin and that would could limit how much you put to the motor. I know of one car in the 300 range and they havent had a problem yet. I would say the 300hit would be the worrysome range, but thats just a guess as I haven't messed with them personally.
If you push it too much it will happen but that could happen with anymotor, you will have better chances with a head with more deck. I would recommend any style head from Performance inductions formally ETP castings then prolly trickflow 245 stuff or bigger. depends on your budget really.
