how much power will a stock motor hold??
8 second mod
i have a white camaro, z28, it was built in october 98, i have a stock motor with 38,000 miles. how fast will i run and how much power will it make and will the stock motor hold up?
LOL Just make sure that you take your bottle out. Those thing are very heavy and your car will be much lighter and faster with it out. Oh and your car should hook better.
well since you asked, Ill tell you the faccts, the stock motor is a POS, what you really should do is upgrade to a LT1 they can hold 3x as much as these POS motors and you can also get turbo power with them, Turbo plus NAWZ is the only way to go and there is no limit when you put these two together, it is a like a special advantage GM put into those LT1 motors, guess the secret is out now.
good luck
good luck
Guest
Posts: n/a
Alright here is how you can get away without having to tune your car if you dont have the Conuter/ Flux mod. If you take some black duct tape and place it on the front right fender with a strip about 5inchs long and 3 pieces thick then from here you will need some gray duct tape and you will place it on the left rear fender with a strip about 5inchs long and 3 pieces thick it will create a postive vib in the cars aura thus no tuning.
just go ahead and spray the crap out of it, start with the 200hp jets. Throw some tr6 plugs in while your at it. Don't worry about the stock rear either they are good til about 9.90s.
8 second mod
thanks for the info guys., got to the track went 6.60 at 88 mph and ended up going back to 1966!!!!! crazy.
nothing was invold in this post. i had just deleted my 3rd or 4th stock motor post, so i thought i would toss this up. clutter my section myself for once. lol
My pieces were four inch not five.
I would increase timing to around 40. On a 200 Shot I hit 968 Rear Wheel HP! I'm going to buy a Tornado and weld the nozzle in the Tornado so hopefully I will be over the 1k mark. It's a good thing you don't have Ram Air or you could blow a crater in the ground surrounding your vehicle.
