got my z06 to the track on spray
8 second mod
got there on spray friday. still cant shift the car for ****. i think the clutch is dragging so bad its screwing up my sincros now. might have to pull it sooner then later.
so granny shifting and spinning i ended up with an 11.6 @ 124. i was happy with that. that was my first pass. went up for a second and spun real bad so i ended up shutting the notrous off and ended up with a 2.3 60 and running 12.4 at 119.
i was happy. injectors where not so happy. running up to 116% duty cycle lol
car has a cold air kit drag raidials and thats about it. 125 shot.
Congrats. Sounds like the car has 10 with more seat time...
What size injectors?
One problem with our hydraulic clutch systems is the heat that builds up in the fluid...
Pump the clutch pedal a lot. Prior to the burn out, while you're rolling from the burnout to the stage, and after the traps - all the way to the turn-off. Gotta keep circulating it.
I have the RAM adjustable and it works fine. I also change out the fluid after 3 passes or so - depending on how much time I'm sitting between passes.
Good luck and get back out there.
