looking for lt1 stand alone fuel system
Old 04-27-2010, 01:03 AM
Restricted User
kalebm22's Avatar
Default looking for lt1 stand alone fuel system
ive seen that nitrous outlet has one for $550 does anyone sell a cheaper set up or have a list of parts that i can put together to make one just as reliable for a little less money? i want to keep the factory 43.5psi so my jetting isnt way off. i have the hsw $350 kit and want to upgrade so i can run race gas in it and wont have to pull timing on the street when im running pump gas. thanks for your help. also i have the 4an kit
Old 04-27-2010, 07:32 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
Originally Posted by kalebm22
...so i can run race gas in it and wont have to pull timing on the street when im running pump gas....
this is not the reason for a dedicated fuel system.
Old 04-27-2010, 09:35 AM
Restricted User
kalebm22's Avatar
well what is, im new to nitrous. but i dont want to get detonation wen im running pump gas in the tank. wat do you recomend for my setup?
Old 04-27-2010, 06:50 PM
BADMOON's Avatar
Always pull timing when spraying. What do you have for a fuel pump for the motor? Stock? Intank 255?
Old 04-27-2010, 10:17 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
Reasons to use a dedicated fuel system:
1) supply ample fuel volume
2) easily adjust fuel pressure for A/F ratio tuning without affecting NA tune
3) different octane fuel
They are not intended to remove the need to retard timing or any other "tuning" that needs to be done with nitrous.
to give you suggestions on what is right for you I need to know more about your car. Feel free to give me a call at the shop or PM me and I will be happy to go over it with you
Quick Reply: looking for lt1 stand alone fuel system
