50 shot with tvs1900
Old 05-06-2010, 10:09 PM
schino's Avatar
Default 50 shot with tvs1900
ill most likely be running a small shot on my truck with roush tvs1900. question is would it be best to go before the supercharger or after and wet or dry? ive got a wet hsw/nos nozzle setup now and was going to make my own plate anyway. it wouldnt be much harder for me to make a plate to go between the blower and manifold instead of throttle body and blower.
let me know what you think and the pros and cons of them. also if you think i should run nitrous at all on a cam only 4.8
BTW it will be about 9-10lbs boost
Old 05-06-2010, 10:47 PM
itsslow98's Avatar
JUst FYI running a 50 shot through a roots blower like you will be will result in 80+rwhp/100rwtq most likely..... instead of the actual 50. So take that into consideration as well.
Old 05-08-2010, 10:12 AM
schino's Avatar
id figure it would pick up a good amount more because of the cooling effects. could even jet for a 30 shot and have the bottle last me a long time. i just wasnt sure if spraying nitrous and fuel through the blower would be a problem. im still unsure
Quick Reply: 50 shot with tvs1900
