Odd problem with HSW switch panel
Old 05-14-2010, 04:18 PM
SuperSlow02's Avatar
Default Odd problem with HSW switch panel
Im really...really stumped on this one. I havnt used my nitrous in a loooong time, and over winter I pulled the 6 speed and went to an TH400 with a TB, Well I tapped into the power wire that went to my switch panel to supply power to the transbrake, well I hooked everything back up and now my switches dont work at all...theres 12v in the wire but nothings happening when I try to arm. The Transbrake works fine, and If I use the orginal toggle switch they sent, everything is fine, the system arms and everything. Now heres the real kicker, I only had 1 switch wired up(just the nitrous system) and its only been 1 switch that ive used since I bought it, So i just swapped switches...nothing, still dosnt work. It dosnt work on the other 3 which are technically brand new.....Any ideas guys?
Edit...this is on a Ashtray switch panel btw
