383 with dp 200-300, couple questions
1.) Could a hydralic cam be used or is the solid a better choice.
2.) NOS or NX kit, and reason for choice.
3.) What pistons will hold up to the abuse.
4.) What is a good stall for th400 with 4.10"s and 3400 lb race weight.
Back ground info: The 383 would be a 4" stroker on a 3.905 bore 00' alluminum block. The n20 will have a stand alone fuel system, wot switch and window switch. 12 bolt, suspension, and exhaust are all top of line pieces. New to the nitrous so I am looking for some info from those who have done dp systems.
