microedge questions....
Old 06-09-2010, 08:17 PM
stonemonk's Avatar
Default microedge questions....
I'm considering picking up one of these, seems like a pretty sweet deal. But I'm wondering about a few things, one in the add it says:
Up to three (3) files can be saved within the MicroEdge unit for quick and easy loading between runs.
Does this mean u can only load three of its options at one time, or you can have 3 "tunes" you can load using all the features?
2nd question is what does it hook up to? Just curious as to whats involved....
3rd question is about the nitrous solenoid delay to prevent lean spikes, how much of a delay can it provide, i have a slight lean spike w/ my direct port and this sounds like it could be the solution.
Old 06-09-2010, 08:32 PM
RealLiveMD's Avatar
1, you can load 3 dif files that have different options like gear lockout pedal delay etc.
2. hooks up to solenoids, power, tps, rpm and wideband if you want
3. it can delay it enough I think in .1 sec intervals.
Old 06-09-2010, 09:40 PM
stonemonk's Avatar
1. ok so u can load more than 3 features per file then.....
2. what about for gear lock out?
3. is there a max on how much it can delay?
Old 06-09-2010, 11:22 PM
89ROC-Z's Avatar
Yes you can load three different "tunes" as you can load every feature per file. One can be set up for strip, one for roll and one from a dig on the street etc.
IIRC it can lock out gears 1-4.
...I wish i had the camaro in the house to look lol. I 'think' up to 2 seconds?
Give Nick or Mike a call 610 534 1004, They helped me out with everything.
Old 06-10-2010, 08:24 AM
rambodog's Avatar
This is 1 program I set up. you can do 2 more different programs & than toggle to anyone that you would like to use.
https://ls1tech.com/forums/nitrous-o...does-look.html
Old 06-10-2010, 11:09 AM
RealLiveMD's Avatar
1. yes, however you want to configure the file
2. yes, for any gear, Although I'm the only person that seems to have problems making that feature work.
3. yea I think its up to 2 sec in .1 intervals.
