Are nitrous jets interchangeable??
Old 06-10-2010, 09:31 PM
gateman's Avatar
Default Are nitrous jets interchangeable??
Are the different mfg's jets interchangeable.?. I am running a plate system from N2O, but ran across alot of NOS jets from my local speed shop for free....
Old 06-10-2010, 10:51 PM
danieloneil01's Avatar
Yes, just make sure what Fuel Pressure they're rated at for the jet size.
Old 06-10-2010, 10:53 PM
camscam02's Avatar
You mean a nitrous outlet plate? if so, the NOS jets are not the same and are NOT interchangeable.
Old 06-10-2010, 11:56 PM
WS6Power's Avatar
No! There are at least 2 different types of jets.
Old 06-11-2010, 12:06 AM
01SOMZ28's Avatar
hmm interesting. I have a nitrous outlet plate and i have a couple NOS jets and they seem to work fine....I've never sprayed with the jets though. I just put them in and tightened the line and it worked out.
Old 06-11-2010, 01:22 AM
camscam02's Avatar
NOS has a long stem compared to n20 outlet, hsw, nx, zex all run a short stem style jet
Old 06-11-2010, 09:37 AM
Well spank my *** and call me susie. I have Nitrous Outlet jets and NX jets that I rotate out. Thought they all used they same style.
Old 06-11-2010, 09:47 AM
6point7s14's Avatar
Dang i use all types with my hsw plate also
Old 06-11-2010, 01:01 PM
camscam02's Avatar
You can interchange jets as long as they are the same style. There are basically 2 common types, a "NOS" style and "NX" style as I like to call them, TNT, HSW, Nitrous outlet, zex, all use the "NX" style which is a short stem, "NOS" has a longer stem and if you wanted to use it, you could cut some off but thats in emergency situation.
Old 06-11-2010, 03:03 PM
Chris@NitroDaves
Guest
Posts: n/a
Not only does the NOS style have a longer stem they are also flared at the base where it meets the head of the jet.
Old 06-11-2010, 04:05 PM
camscam02's Avatar
good call, I dont think I knew that. 2 reasons why they dont work.
Old 06-12-2010, 08:49 PM
gateman's Avatar
thanks, eveybody......
Old 06-14-2010, 01:18 PM
Chris@NitroDaves
Guest
Posts: n/a
Your Welcome
Quick Reply: Are nitrous jets interchangeable??
