what should i expect
Old 06-12-2010, 10:23 PM
JUICED01's Avatar
Default what should i expect
i have a 01 camaro a4 3.23 gear that has a cat back and an air lid with a 150 wet kit and a hsw stand alone what ets you guys think went a 13.17 @ 105 on motor
Old 06-13-2010, 10:18 AM
BAKED's Avatar
Auto or 6 speed?
Old 06-13-2010, 02:35 PM
JUICED01's Avatar
its a auto
Old 06-13-2010, 02:49 PM
Blk97WS6's Avatar
If you can hook it i say low-mid 12s
Old 06-13-2010, 04:27 PM
Black99TransAm's Avatar
i knew someone that went 13.4@104 na and on a 150 shot went 11.8@116
Old 06-13-2010, 05:17 PM
AutomagicLS1's Avatar
Either way it should pickup 12-13 mph
Old 06-13-2010, 06:03 PM
BAKED's Avatar
Spray it off the line and through the shifts and if the tranny holds you should be able to 'squeeze" a solid 11 sec pass out of it.
Old 06-13-2010, 07:07 PM
JUICED01's Avatar
well had a few issues low bottle pressure and track was junk went 12.25 @ 117 with a 1.92 sixty today i honestyly thought iw would go in the 11s it might
Old 06-14-2010, 08:09 AM
Blk97WS6's Avatar
I called it! What do I win???
Now the next time you spray it, now that you see how it feels, I bet you hit 11.9
Old 06-14-2010, 09:52 AM
Nick@HSW's Avatar
You'll eventually get there...first time out, not too shabby.
Nick
Old 06-14-2010, 05:01 PM
Chris@NitroDaves
Guest
Posts: n/a
Get the pressure issue figured out and get that 60f down and you might hit your 11.
Old 06-27-2010, 08:45 PM
JUICED01's Avatar
well went back and went a 11.86 at 119.55 tranny is slippn lol
Old 06-27-2010, 09:48 PM
2500HD6.0's Avatar
nice good run
Old 06-27-2010, 09:51 PM
dnkynrbk's Avatar
LOL that has happen before to all of us man. Welcome to the club. Now save money for a built tranny and a good stall. I would also go to a 3:42 gear thats what I had in my old set up with a PerformaBuilt 6oE Was greared perfect for a auto 26in tall slick.
Old 06-27-2010, 10:45 PM
JUICED01's Avatar
im working on a trans now i want a 3.42 but think im gonna wait till i put a 12 bolt for that
Old 06-27-2010, 11:35 PM
itsslow98's Avatar
You might be waiting for a while, the stock 10 bolts with autos can actually take a good beating, they dont take half the abuse as M6 cars. Gears arent expensive id go ahead and put them in if i were you.
Old 06-28-2010, 01:45 AM
MontecarloDrag's Avatar
Rebuild the transmission and install a shift kit to make it live longer and shift faster.
Then go for 3.73 gears and a torque converter with at least 2400 stall.
With those mods, practice and good luck you will lower your ET at least 0.3 more
Old 06-28-2010, 03:30 AM
itsslow98's Avatar
Then go for 3.73 gears and a torque converter with at least 3600 stall.
fixed it for ya, 2400 stalls in an fbody are a joke.
Old 06-29-2010, 09:40 AM
chevyconvert's Avatar
JUICED01,
What tire are you using and how are you launching?
My dad has an 01 ss with just about all of the bolt ons and a cam. He is running NT05r drag radials and it bogs bad off the line and cannot get below a 2.00 60ft in the heat.
Old 06-29-2010, 12:29 PM
brians91formula's Avatar
Originally Posted by chevyconvert
JUICED01,
auto or manual ? gears ? converter ?
