Can I convert a NOS wet kit to a NO LT1 plate?
I'm going to trade my supercharger for a nitrous kit? It's a nos wet kit and I really wanted to run the nitrous outlet plate, if I just purchase the lt1 plate will everything else work like the nitrous outlet kit?
Should work fine... as long as the nitrous and fuel lines that connect to the NOS fogger nozzle are the same size that the Plate will need. usually -3AN. If not, then you'll just have to buy two new lines. You Will NEED to use Nitrous Outlet Jets tho. NOS jets will not work on N2Outlet plate.
Just got make sure the fittings will hook up and everything else will work. I actually think the plate is -4an.
Once its together just want to double check all your tuneups.
