200 shot on stock LS1?
Old 06-14-2010, 12:30 AM
camaro981289's Avatar
Default 200 shot on stock LS1?
Can a Bone stock LS1 motor take a 200 shot of nitrous without causing damage? People say it can but i believe 150 shot is max on a stock ls1 motor.
Old 06-14-2010, 12:36 AM
camscam02's Avatar
yes it can if the fuel system can support it and its has different plugs
Old 06-14-2010, 12:44 AM
Im thinking of going with the zex wet kit...what plugs are recommended? TR6's??
Old 06-14-2010, 12:48 AM
I believe the block can handle it but what about the rings?
Old 06-14-2010, 12:52 AM
JonCR96Z's Avatar
I've seen cars run a 200 shot with too hot of a plug on a bad tune up and be fine. They only did it a time or two, though. And they didn't really gain much.
The tune up needs to be spot on to make it safe and to be worth doing.
Old 06-14-2010, 01:01 AM
MYSTIC-1SC's Avatar
yep it can be done, but the tune better be spot on if you want it to last any amount of time.
Old 06-14-2010, 04:55 PM
Chris@NitroDaves
Guest
Posts: n/a
Also to add to what he said you need to make sure you have the correct amount of timing pulled and the tune up has to damn near be spot on or it's gonna go bad real quick.
Quick Reply: 200 shot on stock LS1?
