The poping through the exhaust is normally unburned fuel. What is your airfuel ratio on the bottle?
Dave
I thought it was probably unburned fuel as well. Not sure what the afr's are on the bottle, its been a while since i was on the dyno. I'd have to find my last dyno sheet and look. I haven't changed anything since then.
You dont have a wideband or a means to log anything?
...no.... I live life on the edge. I haven't had a wideband or anything to long the last 2 1/2 years i've had the nitrous on the car. Although i have been looking into getting a wideband here recently...
I'd make a pull and then kill the car and pull some plugs to see where your at on fueling. The plugs are going to be the best way to find out without a wideband cause the plugs are the all tell.
