Nitrous Outlet, come here!
Old 06-17-2010, 04:29 PM
01SOMZ28's Avatar
Default Nitrous Outlet, come here!
I'm going to unzip my vagina and let my ***** hang out and run a 175 shot. I'm running your 78mm plate with some NX solenoids. I've had the solenoids on the car and spraying for a little over 2 years. Do you think these solenoids are sufficient enough or should i upgrade?
Also, how much timing should i pull? 9 degrees? Will BR7EF's gapped at .32 be fine?
and most important, what jetting would be around a 175 shot? 67N 36-38F?
Old 06-17-2010, 04:48 PM
Chris@NitroDaves
Guest
Posts: n/a
Now thats funny as all hell!!!
Now to answer your questions.
The noids should be fine and for the timing, pulling 9-10* is fine and the plug gap is ok too. The 175hp jetting will be 73N20 39Fuel
Old 06-17-2010, 07:08 PM
01SOMZ28's Avatar
73N?! The jet calculator i use says thats a tad over 200hp? My calculations show its around a 67N? I thought the chart i have from you guys shows a 74 as a 200shot?
Old 06-17-2010, 07:20 PM
brokenbird's Avatar
thats 175 to the tire
Old 06-17-2010, 07:27 PM
01SOMZ28's Avatar
Yea the calculator i used said 67N is 172rwhp....
Old 06-17-2010, 08:35 PM
GMMillwright's Avatar
Their jetting says .078 is a 200, but I think it's more like 225 with a correct tune. NO lists .046 for the fuel side, but I'm sure that's really rich.
Old 06-17-2010, 09:29 PM
01SOMZ28's Avatar
hmm i have a .62 in right now for a 150 shot. The calculator says the .62 is 147rwhp. Why would it be wrong on the .67 for a 175 shot? I can't believe i'm questioning the boys at Nitrous Outlet lol just trying to get this right
Old 06-17-2010, 10:01 PM
Carter01's Avatar
50- n35 f22
100- n52 f33
150- n62 f38
200- n78 f46
Not sure about the 175 but these are the jets in 50 hp increments.
Old 06-17-2010, 10:31 PM
01SOMZ28's Avatar
Originally Posted by Carter01
50- n35 f22
100- n52 f33
150- n62 f38
200- n78 f46
Yea i have that jetting chart and jets up to 250. I can tell you one thing and that is their chart on the fuel side is way rich. A 150 in most cases should be N62 F33. I hit the dyno after i installed the plate. I went off their chart for the 150 shot. My afr's dipped into the 9's with that .38 fuel jet, pig rich! Took it out and put the .33 back in. I was told from another member on here that a .67N .36F would be around a 175 shot. A .73 jet seems huge for a 175 hit.
Old 06-17-2010, 10:38 PM
Carter01's Avatar
So your 150 is 62/33? That helps me for that is what I will be spraying very soon. Did you check the a/f with the 33 in there since the 38 put you into the 9s?
Old 06-18-2010, 03:49 AM
camscam02's Avatar
loooks like people are learning around here. good job guys!
Old 06-18-2010, 09:17 AM
01SOMZ28's Avatar
camscam02 i think you were the one that told me in another thread that a .67N .36F would be about 175.
Old 06-18-2010, 11:01 AM
Ls1tech & Truck Sponsor
NitrousExpress's Avatar
Which soleniods Is that you have sir?
Old 06-18-2010, 01:22 PM
LT1 Trash's Avatar
my .62N .35F in my nitrous outlet plate gained extactly that 147whp and is right at 12.0 a/f with 6* pulled(21 total). i'll be going to 175 soon and was thinking around .67-.70
Old 06-18-2010, 01:50 PM
Nitro Dave's Nitrous Outlet's Avatar
The online calculators are a generic form of coming up with a close jetting. However it is not the most accurate way of doing so. It does not take into calculation certain things.
Different products have different flow charastics. For example a plate versus a nozzle may have complete different jetting. Two different types of directports may have a different jetting as well. The jetting is determained by flow.. Not an online conversion.
All of our jetting is figured at the rear wheel. And if you look at our customers results its pretty much dead nuts on.
Your best bet is to always listen to the manufacture that makes the parts you are using. Not some one online or your buddy down the street. After all how could they know more about a product than the company that makes it?
A 175 jetting is 73 nitrous and at 55psi we suggest a 38 fuel pill. Our jetting is rated at the rear wheel not the fly wheel. We are more interested in rear wheel horse power than fly wheel horse power.
So happens if you look at many of the nitrous companies that use rear wheel hp on there single nozzle systems they are seeing a 73 jet as being 175 at the fly wheel as well.
Our plate shares the same flow charistics as our nozzle as far as X amount of nitrous flow equals X amount of power to the rear wheel.
Listen to us. We know more about our product than anyone else.. Only makes since right?
Dave
Old 06-18-2010, 02:29 PM
camscam02's Avatar
Answer me this dave... you use a 62 jet for the 150 as well as a couple other companies use that same size jet for that shot, yet for the 175 and 200 you use a significantly larger jets then those same companies for those same size shot. Now you say its based on flow... so your plate needs more jet to flow what the other companies nozzles/plates flow for that given hp from 175 up??? Kinda see what im getting at here.
Old 06-18-2010, 02:40 PM
Cam,
I am limited to what I will share in the area as some of it is propriatary knowledge.
Why dont you break down what you are comparing what to and I will do my best to explain it to you with what info I am willing to share.
Dave
Old 06-18-2010, 02:54 PM
camscam02's Avatar
Originally Posted by Nitro Dave's Nitrous Outlet
Cam,
Dave
Thats a lot of research I really dont feel like doing really. It was just interesting to me so I thought I would comment on the jet size vs flow part.
All I was comparing was the jet size needed for a certain shot. and how they are mostly the same for all manufactures at 150 but then get different and some by a large margin which leads me to flow and you obviously need more jet to flow x amount of nitrous to reach the 175 or 200 hp level.
Now im not arguing or saying so and so is better, but just an interesting observation.
Old 06-18-2010, 03:36 PM
I asked for the info to back your observation so that I could explain the differences to what you are comparing. Need to make sure you are comparing apples to apples. Out of al the nitrous companies suggested jetting charts I have most of the companies are pretty similiar to each other. You have to make sure you are comparing a similiar part to a similiar part and rwh to rwh vs fw to fw.
Dave
Old 06-18-2010, 03:46 PM
SexyTransAm's Avatar
some damn good info in here
Quick Reply: Nitrous Outlet, come here!
