HSW 90mm plate jetting?
I'v been all over hsw's site and I have searched on here, but i'm trying to get jetting for 175, 200, 225 for a HSW 90mm plate.
Also i'm confused on the differences in the sudden impact kits and the brute force kits. Are the solenoids different? Why can you only spray a max of 150-175 on the sudden impact?
The directions for this HSW kit says sudden impact, but the kit has the larger solenoids, not the little peanut solenoids.
Also how much is the HSW 90mm plate capable of spraying?
Either way i'm looking for jet sizes for 175, 200, and 225 for this plate
thanks
thanks
Check this calculator out. it's pretty accurate with the HSW chart for shot size.
http://www.robietherobot.com/NitrousJetCalculator.htm\
Or just call HSW.
as far as max shots, I found this thread on the HSW message board.
http://www.harrisspeedworks.com/foru...opic.php?t=361
hope this helps. try posting in the HSW message boards. Matt is real good at replying quickly to questions on there.
Oh and do you ever come down south any???
Or just call HSW.
thanks
thanks
Nick
