Rookie standalone ?'s
I am totally new to Nitrous but am trying to learn. I have searched but have not found the answers. I am considering the NMCA Street Race class.
What is the main purpose of a standalone system?
Can I use the factory fuel tank and use a regulator to reduce the fuel pressure since I will be using a carb?
Thanks
Thanks
The reason for a stand alone fuel system is if you don't have enough fuel supply with your current fuel system. With a high hp motor set up fuel demand is already very high. Then if you install a high hp nitrous system it can be very hard to keep pressure and flow.
Guest
Posts: n/a
Thanks
Thanks
You can use the factory tank but will need to change the pump and lines from front to back to do it right.
The main purpose of a Stand alone is to ensure that you are 100% covered for fueling on any giving shot while also have the ability to run 100% race gas instead of a mixing in the stock tank. A stand alone ( Depending on Regulator used ) will also allow you the ability to adjust the fuel pressure to fine tune the nitrous setup whether it be low or high pressure.
Thanks for the response. Would I still need a standalone system if I changed the entire tank? What about if I was running a carb?
Thanks
