calling anyone from HSW, please let me know what you think?
Okay got my nitrous going. just when I let off of throttle after running the nitrous, the car will stall and the a/f gauge will go to 10.0.. when I get it started the a/f will be rich and it will take about 20-30 sec. for the a/f to go back up. I pulled off the plate, and hit it in a bucket w/just fuel going thru it, and you can see where the fuel still runs after I let off and you can hear the selonoid shut off. I took apart the selonoid and cleaned it out, and the plunger and seal looked great. "the noid is new". only about 5 runs on it.
Does this seem like a bad noid, or maybe something on the microcontroller setup? It just seems like the extra fuel in the line is bleeding out thru the plate. any thoughts?
http://www.youtube.com/watch?v=a0ro2AhGRdU
and this one...
http://www.youtube.com/watch?v=imMCbVVKpKs
and this one...
and this one...
and this one...
nick
Did you get the problem resolved?
I just did a quick check for functionality on my plate ket with the test mode thru the microEdge. I just ran the nitrous & fuel line into separate gatoraide bottles. Purge worked, nitrous line blew the bottle across the garage, & fuel puddled a small amount into the other bottle. So it looks like all is working. I need to put in the br6ef plugs and start some real world testing next weekend.
Yeah I got it going better, It was mostly my controller setting, I had it set to where the nitrous would kick off when I almost fully let off the pedal, I set it to shut off alittle sooner. now it comes off as soon as I start to let off the throttle, if I let off about an inch off the pedal now. Plus I plan on ordering a shorter fuel line.
