need a wiring diagram
Old 06-20-2010, 12:19 PM
ls2 bait's Avatar
Default need a wiring diagram
anyone on here do these anymore? im going to rewire my system to try and cure some voltage issues im having.
dedicated pump (want this on the same switch as my arming switch)
n20 outlet progressor w window and tps switch
big show purge
switch to os5 (this can be on a seperate switch i have an extra one)
synergy 2 step (already wired in i need it to turn off n20 when activated)
well thats the jist i can get more in depth if i need to. any help is greatly appreciated
Old 06-20-2010, 10:36 PM
waterproofer's Avatar
u need some relays. use the arm switch to turn on both relays. tps ck all three wire with meter u r looking for the with the key on and should read .5 volts at wot. easy
Old 06-22-2010, 11:55 AM
Chris@NitroDaves
Guest
Posts: n/a
I wish i did but i can't help with the OS5 stuff. Beer99C5 might ahve a os5 diagram the might help you out. I'd PM him and ask.
Old 06-22-2010, 10:08 PM
ls2 bait's Avatar
i will do. did you get the email i sent you chris?
Old 06-22-2010, 10:09 PM
ls2 bait's Avatar
im sorry which one of those were you talking about?
Old 06-23-2010, 11:52 AM
Chris@NitroDaves
Guest
Posts: n/a
I did get the email and have responded.
Old 06-24-2010, 11:50 AM
3fingas's Avatar
os5=cos5? If so you can tie it in to your WS ground. I have 1 switch throwin 12v at 2 relays and WS. I have the trans brake and 2step wired on a separate circuit.
Arm>Relays (Noid,FP) and WS.
WS/GND> Noid relay, PIN56, low oil lamp (lol).
Still using a micro switch though I have a microedge sitting in the shop for couple of months now.LOL
I also tie in purge grnd to FPSS so if it aint purgin, somethins up.
You can power your noid relay to 2step 87a.
Old 06-24-2010, 12:51 PM
ls2 bait's Avatar
holy crap i just got lost. haha. thats why i need a diagram. low oil light? is that so you know its active?
Old 06-24-2010, 02:25 PM
3fingas's Avatar
LOL. Sorry brotha.
Not sure bout nitrous outlets controller but to ground pin 56 on cos5 if you have it flash'd in. You can either:
Switch it (dont forget to throw the switch)
Tie it in pin 56 to the WS ground. This will ground pin 56 when the WS grounds the noid relay. If thats the way their WS works.
Or you can add another relay and tie pin 56 to 87 and 30 to ground. Tap in power to 86 from arm switch. This way when you arm, ur in cos5.
as far as ur 2 step and N20. Not sure how ur launchin the car but if you tie in ur 2 step relay 30 to noid relay 87a. Power to the 2 step cuts when the N20 relay activates.
The low oil lamp will activate when My cos5 is up. Mines a 98 cluster.
Sorry no diagram.
Old 07-11-2010, 11:31 AM
ls2 bait's Avatar
bump......ill pay.
