New Engine build 408 W NITROUS OUTLET D.P
Old 06-20-2010, 09:08 PM
dnkynrbk's Avatar
Default New Engine build 408 W NITROUS OUTLET D.P
I was contemplating on what to do this summer. I'm still stuck on pushing spray to the limit one more year. So why not build a bad a$$ 408 head and main stud and start the spraying at 250 then go up to 400 shot toward the end of summer.
With the old 370 I had it went 9.78 with a safe tune and in a 3600lb car. The car still has air bags,interior and stock K member and A arms.
I may put her on a diet.
So I'm going to start my build and try and post pictures up of the motor assembly and engine and trans going together.
Thanks to Dave @Nitrous Outlet for the helping with all the nitrous knowledge.
Car will be going to to Daves late summer to get the final teaking on the Nitrous tune.
Engine specs.
408 iron block
Callies :TU: the expensive stuff :mrgreen:
Diamond coated nitrous pistons
Callies rods
ARP head and main studs
Ported melling oil pump.
Yella Terra LS1/6 Non-Adjustable Rockers
Reworked patriot stage 3 heads ported and milled compression 12-7
GM CTS-VR Racing Team Hyd. Lifters
Cam Motion custom n20 cam spinning 7400 rpms
Ported Fast 90 with Nitrous Outlet D.P done by Dave.@N20 OUTLET
90 MM N.W T.B
Nitrous Outlet dedicated, w/acc.
Kooks stepped race header 3 1/2 collector
3 1/2 BULLET mufflers and exhaust dump past the tranny.
PerformaBuilt T400 with new rmvb from ck performance.
Neal chance N20 5200 stall
NITROUS OUTLET D.P.
Some cosmetic upgrades
[img]https://i294.photobucket.com/albums/mm112/JSFORGED408/100_2270.jpg[/img
Old 06-20-2010, 09:34 PM
nastychevelle's Avatar
missed one
Old 06-20-2010, 09:40 PM
brandoz28's Avatar
looks good man, what's your goal for it with the new bullet?
Old 06-20-2010, 11:00 PM
dnkynrbk's Avatar
Hoping for low 9s on a 300 shot.
Old 06-21-2010, 02:15 PM
TRU-2GM's Avatar
NJFTMFW!!! Sick man sick!
Old 06-21-2010, 05:09 PM
camscam02's Avatar
put a real set of heads on it, otherwise looks good, seems like the same setup with like 30 more cubes...
Old 06-21-2010, 05:49 PM
nick.celis's Avatar
that looks like a badass setup!!
Old 06-21-2010, 08:31 PM
dnkynrbk's Avatar
Im saving my money to. Wish good heads were cheap but then everyone would have them
Old 06-21-2010, 09:12 PM
Carter01's Avatar
Looks great man, what type NA numbers are you expecting?
Old 06-21-2010, 09:24 PM
dnkynrbk's Avatar
At least get a low 11 or high 10s .The nitrous stall really robs your time NA.
Best I got out of the 370 Na was low 11s with that stall. If you talk to alot of guys on here that have a Big Nitrous stall they are usually around that area high 10s low 11s. Then when you push it with spray thats when the stall really does its job.
Old 06-21-2010, 09:43 PM
camscam02's Avatar
I agree with that, pretty much why I havent touched mine. Not worth it until I can purchase a good one. 2500 bucks later...
and yes with the tighter converter in it mine is an 11.0 car is really good weather on motor. 200 worth puts it in the 9.70's. hoping to get in the 50's now maybe 40's with the new upgrades...
Old 06-21-2010, 09:48 PM
LS1 SPEED's Avatar
looks good and good luck with your goals
I bet with FTP lid and Chrs1313 RA you would see big gains over that K&N setup.
Old 06-21-2010, 10:05 PM
V-10 Killer's Avatar
I can only imagine what kind of ride this must be!
Old 06-21-2010, 11:17 PM
1MEANGTO's Avatar
Looks like my shop car it's almost done. Wish I would have dona a th400 now though. Well I'm sure the one on the shelf will end up in the camaro. I'm hoping for low 9's on a 300 shot.
Old 06-21-2010, 11:24 PM
dnkynrbk's Avatar
Im just trying to keep it as budget friendly as possible. I recently got married and that took all my extra money. lol but she lets me race whenever I want.
Old 06-22-2010, 02:30 PM
chrs1313's Avatar
like Larry said definitely get a ram air setup in there...right now you are getting alot of engine heat and no ram effect...I would say an easy 3mph gain with a FTP lid and a good ram air setup...
Old 06-22-2010, 02:37 PM
Chris@NitroDaves
Guest
Posts: n/a
Looking good John. Cain't wait to see it hit the track.
Old 06-22-2010, 07:25 PM
...and yes with the tighter converter in it mine is an 11.0 car is really good weather on motor. 200 worth puts it in the 9.70's. hoping to get in the 50's now maybe 40's with the new upgrades...
Sweet, I have something to pray for this year. I'd even be happy with .2 slower. My car also runs 11.0-11.1's on motor, and I specced my converter pretty tight for spray too too.
Old 06-22-2010, 08:33 PM
dnkynrbk's Avatar
Thanks Chris. I cant wait either lol.
Quick Reply: New Engine build 408 W NITROUS OUTLET D.P
