Would My System Work On An LT1 Or Other Car?
Old 07-02-2010, 10:10 AM
Bill'sWS6's Avatar
Default Would My System Work On An LT1 Or Other Car?
I have the car in my sig, 2000 SS with a Cold Fusion wet kit that has the nozzle that you put through the bellow.
I am thinking of getting selling it since it has only had one bottle through it and I never use it. It has all the bells and whistles including purge, timing tuner, bottle heater etc.
A friend of mine that has a 95 Camaro asked if it would work on his and I said I don't know? Since it works off a WOT switch wouldn't it work on other model cars besides the Camaro (98-02)?
Thanks for the feedback.
Oh, by the way, do you need to pull timing even on a 50 shot?
Old 07-02-2010, 10:31 AM
Ls1tech & Truck Sponsor
NitrousExpress's Avatar
Its its just a universal wet single nozzle kit it should be fine.
The WOT switch will work he may just need to tweak the bracket or buy another. On a 50 shot it should be fine. Just make a pass and check the plugs. Make sure he is running 91-93 octane.
Old 07-02-2010, 11:55 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
yes....it will bolt on the car, but the LS1 and LT1 run different fuel pressures, so you will need to adjust the jetting.
Please contact Cold Fusion and get the suggested jetting for thier LT1 systems and pass that info to your buyer.
And yes you should always adjust the timing with nitrous use.
Old 07-07-2010, 07:14 PM
Bill'sWS6's Avatar
Thanks To Both Nitrous Express & Nitrous Outlet For Your Replies.
