Whats the biggest shot I can run with NX wet kit single nossle...150 or 200?
Old 02-09-2004, 11:36 AM
SStroked 410's Avatar
Default Whats the biggest shot I can run with NX wet kit single nossle...150 or 200?
I was told with the single nossle it would max out at 150-175
and I found out theres a 200 shot for this single nossle
heres the n20 jets for a 175 and 200 and would like to know if anyone has ran a 200 shot with this kit?
N20 Fuel
73 38 175 Shot
78 41 200 Shot
If not does NX make a bigger nossle for 200-250 shots?
Old 02-09-2004, 11:29 PM
vette=lack of penis
Cursed1's Avatar
N20 Fuel
73 38 175 Shot
78 41 200 Shot
The kit maxes out at 150hp with all of the factory pieces. From what I understand the only thing that you have to replace is the -3an from the N2O solenoid to the Nozzle. You have to upgrade it to a -4an line. This will allow you to be able to utilize the kit for a larger shot. Hope this helps.
Old 02-10-2004, 12:42 AM
C4VetteLS1's Avatar
Your incorrect.
Kit maxes out @ approx 220 rwhp (from lots of testing).
The main limitations on a standard NX wet kit weve found is the 4an line and nitrous solenoid. Weve made 300 rwhp through the 3AN that were 1-2 ft long. Standard nozzle will flow 300 rwhp techinically.
Nitrous Express also makes a SHO kit that will flow 400 rwhp
Old 02-10-2004, 01:04 AM
Restricted User
CAT3's Avatar
Piece meal it I say. Get a nice -6line, room to grow a lil. Some BIG FAT Solenoids, and a roomy nozzle, or twin nozzle, SX2.
Old 02-10-2004, 09:03 AM
SDB
SDB's Avatar
if all you want is 200 hp single, then you need to -4 to replace the -2 line that goes from solenoid to nozzle. I have the MAF kit and NX told me this is what i would hae to do, and that the -4 will easily suppor 300 hp shot (-4 main line). I had anter wet kit on a vette that used a single nozzle and I used the SHO purple nozzle that would support 400 hp single shot.
Old 02-10-2004, 11:16 AM
Ok so I might just go with a -4 and bigger nossle to make it easy and I would later be able to spray as much as a 300 shot right?
Do I have to replace the fuel line that connects to my nossle also? Since its the same size as my n20 line.
I have heard that you shouldnt spray more then a 250-275 shot throught the intake, have any of you had any problems spraying this much through the intake with these nossle kits?
Old 02-10-2004, 05:33 PM
Vents's Avatar
well i've seen over 250 RWHP through a single nozzle w/ a -6 line and big noid and 73/41 jetting (fat i know) but thats only 175 jetting. plenty of room to grow. ;D whats limiting you to one nozzle? class regulations or just curiosity?
Old 02-10-2004, 09:21 PM
Nothing really, just trying to make it simple since I already have this kit
I could also run 2 nossle into the bellows
what would be better?
Quick Reply: Whats the biggest shot I can run with NX wet kit single nossle...150 or 200?
