to those running nitrous main line down pass side of the car
Old 02-12-2004, 02:10 PM
NOTFAST's Avatar
Default to those running nitrous main line down pass side of the car
how did you get the mainline into the engine compartment?
I have the line ran all the way up to the tire well...now i need to get it into the engine compartment as simple as possible
thanks
matt-
Old 02-12-2004, 02:14 PM
Nitro Dave's Nitrous Outlet's Avatar
Pull it through the wiring harness garmet.
Old 02-12-2004, 02:23 PM
NOTFAST's Avatar
where is the hole in the firewall?
Old 02-12-2004, 02:48 PM
EVIL's Avatar
under the pcm
Old 02-12-2004, 05:01 PM
Chris99WS6PWTMET's Avatar
I'm assuming you mean outside of the car. If so, I went through the frame into the fender well, ran it over the top of the inner plastic wheel well, into the bay from the opening by the battery.
Old 02-12-2004, 05:44 PM
algws6's Avatar
"Pull it through the wiring harness garmet."
is that garmet next to the harlem shift light?
Old 02-13-2004, 08:48 AM
taqwache's Avatar
i had my bottle in the spare tire compartment, rand the hose through the inside of the car, under the passenger carpet, through that body plug, around the converter shield, over the k-member and up to the bottom of the air filter. this is a little bit harder but once done you can not see it at all.
Old 02-13-2004, 03:53 PM
Motorboater
SilverGhost's Avatar
you need to remove the plastic kick panel to get at that gromet as i recall. i haven't been in there since i ran my line for my battery when i relocated it. I ran my nitrous line through there when i had a tnt kit before...under the carpet and up through there
Old 02-14-2004, 09:08 AM
RealDealCamSS's Avatar
Mine is inside my spare tire compartment. All I did was run the line inside the car down the door, and up through the hole in the firewall. It was simple. Remove one interior panel and you're there.
Old 02-14-2004, 09:22 AM
Assassin's Avatar
I ran mine under the carpet in the back and through the hole above the gas tank then down along the outside of the car w/ the rest of the fuel line useing zip ties here and there to keep it in place
