Best spark plugs for nitrous???
Old 02-22-2011, 09:05 PM
deangoodin's Avatar
Default Best spark plugs for nitrous???
Ok .iam hopeful down to the spark plug purchase for my new motor.iam looking for best spark plug brand and heat range for my 402 ls2 nitrous motor,any input???
Old 02-23-2011, 10:22 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
How much nitrous? How much compression? What heads?
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 02-23-2011, 11:07 AM
deangoodin's Avatar
243 heads,402 cid,11 to 1 compression maybe little over on 200 shot
Old 02-23-2011, 11:12 AM
cookba's Avatar
https://ls1tech.com/forums/nitrous-o...o-read-me.html
https://ls1tech.com/forums/nitrous-o...rous-info.html
Old 02-25-2011, 03:55 PM
Chris@NitroDaves
Guest
Posts: n/a
I would recommend these
200hp NGK BR7EF [ NGK Stock # 3346 ]
250hp NGK B8EFS [ NGK Stock # 1049 ]
Old 02-26-2011, 09:19 PM
Spdmn75's Avatar
How about LS7 11:5 comp stock heads with 100 wet shot through plate system?
Old 03-01-2011, 09:16 AM
Ls1tech & Truck Sponsor
NitrousExpress's Avatar
There is quite a bit of helpful info on this thread!
READ READ READ!!
Just as Chris said ^^^^ these will work great!
Old 03-01-2011, 11:49 AM
Graham@NitrousOutlet
Guest
Posts: n/a
I would stick with the br7ef. I would probably just run them all the time on that motor. As long as the idle tune is not overly rich they will be just fine handling a 100 shot and daily driving needs.
Graham @ N20
Old 03-01-2011, 09:14 PM
Spdmn75's Avatar
thanks for the info, you guys have these plugs?
Old 03-01-2011, 10:42 PM
Guest
Posts: n/a
Yes sir we do.
http://nitrousoutlet.com/catalog/cat...26&section=101
If you want you can order them easily right off of the website, or you can give me a shout when your ready and ill put the order in.
Graham @ N20
Quick Reply: Best spark plugs for nitrous???
