L19 head studs, who wants them???
Old 02-19-2004, 07:53 PM
Under criminal investigation for fraud
Chris@AP-Engineering's Avatar
Default L19 head studs, who wants them???
Here it is.....we have a chance to get L19 head studs again. I need to get some interest in these to get them ordered up. Depending on how many people we have showing interest will determine the price of these studs. Let's get this going, who's in?
Thanks,
Old 02-19-2004, 08:12 PM
Vents's Avatar
*cough*
Old 02-19-2004, 08:55 PM
angst911's Avatar
what are they?
Old 02-19-2004, 11:08 PM
W8N2SQZ's Avatar
I would like to see a price as well. I am in the market for a set of studs.
Thanks,
Glenn
Old 02-20-2004, 07:20 AM
PSJ Wannabe & Attention Whore
BOO HOO BRIAN's Avatar
Keep in mind, these studs are not for everybody. These are for the boost/compression/big n20 guys. If we get enough sets sold, they will make it a stocking part and the cost comes down severly.
Old 02-20-2004, 07:56 AM
taqwache's Avatar
dam, i already bought APR head studs. if i would of known there was something better later on i would of bought them. maybe someone wants to buy my old ones.
Old 02-20-2004, 08:18 AM
The Bull
DERTY's Avatar
Brian, I'm assuming that you guys are offering them in stock size studs. Or can they order any size they want, like 9/16"?
Old 02-20-2004, 08:26 AM
The Bull
DERTY's Avatar
To help Brian out a bit, here's a description of the two higher level ARP materials that you can get above their standard materials used in head and main studs.
ARP2000
An Exclusive "Hybrid-Alloy" developed to deliver superior strength and better fatigue properties. While 8740 and ARP®2000 share similar characteristics, ARP®2000 is capable of achieving clamp loads in the 215,000-220,000psi range. ARP®2000 is used widely in short track and drag racing as an upgrade from 8740 chrome moly in both steel and aluminum connecting rods. In this strength level, stress corrosion and hydrogen embrittlement are typically not a problem, provided care is taken during installation.
L19
This is a premium steel that is processed to deliver superior strength and fatigue properties. L19 is a very high strength material compared to 8740 or ARP®2000, and is capable of delivering clamp loads in the 230,000-260,000psi range. It is primarily used in short track and drag racing applications where inertia loads exceed the clamping capability of ARP®2000. Like most high strength, quench and temper steels, L19 requires special care during manufacturing to avoid hydrogen embrittlement. This material is easily contaminated and subject to stress corrosion. It must be kept well oiled and not exposed to moisture.
Some good comparison info is available here: http://www.centuryperformance.com/fastenermaterials.asp
Same information can be found on page 20 of the ARP catalog.
http://www.arp-bolts.com/media/pdf_files/arp_cat03.pdf
Old 02-20-2004, 09:10 AM
Steve,
These will br a direct replacement stud. With the l-19 studs, the big SAE thread will not be needed.
Old 02-20-2004, 02:29 PM
Jammer's Avatar
Brian/Chris... I beleive we talked abot this before, but I do need a set ...and will order if you hit that magic number it takes to reduce the price.
Old 02-20-2004, 02:58 PM
The price will be 425.00 a set if we get 25 people.
