direct port lines suck need help
Old 02-29-2004, 08:00 PM
8 SEC SLOPPY SHOT!!!
tuff's Avatar
Default direct port lines suck need help
I'm plumbing my dp setup and i'm only 1/4 way done. All i know is im not going to be happy with the way it looks. does anybody make a braided hose that i can make or am i SOL these steel tubes suck.
Old 02-29-2004, 09:04 PM
The Bull
DERTY's Avatar
You mean like this?
It's all -3 TFE Aeroquip hose and fittings. Each line will cost you about 25 bucks a piece, times 16! The other thing you will have to look at is how to firmly mount everything, as the steel lines support the distribution blocks. With these lines you need to come up with something else. I'll tell you that it's so much easier to change jets with this setup as well.
