2nd stage or just bigger jet?
Old 11-16-2011, 02:31 PM
wreckwriter's Avatar
Question 2nd stage or just bigger jet?
I'm currently running a 100 dry shot into my Procharger pipe before the intercooler. It works VERY well but looking for just a bit more, probably 150.
What would be the best way to do it; add a second stage or just bump the jet size and slow down the ramp a bit with the controller (NOS Launcher)? Any specific advantages to either one other than cost?
Thanks!
Old 11-16-2011, 03:30 PM
soundengineer's Avatar
On a 100 to a 150, just jet bigger...
If you were adding more and were just blowing off the tires at low speeds, then I would consider a 2nd stage to add after you get to a higher speed in a different gear...
Old 11-16-2011, 03:35 PM
Launches fine with the 100, I figure I can just play with the ramp to keep it that way. Here's an onboard video from last week
http://youtu.be/ZGNvvoTmP3U
Old 11-16-2011, 10:20 PM
a4ls2goat's Avatar
What times are you running?
Sounds like you need to adjust your 1-2 shift..
If your nozzle can flow 150 I say just up the shot..
Old 11-17-2011, 02:59 AM
6 & 8 Second Club
mrdragster1970's Avatar
2nd stage is for when you can't control the launch, or you need 2 drastically different HP tune up's.
My 2 cents, KISS and stick with what you're doing until you can't get it off the line.
Plus I'm cheap, why spend all that money just for another 50 or even a little more??
Good luck.
Old 11-17-2011, 06:17 AM
I think the shifts are about as good as can be considering I'm pushing 720 HP with a stock 6L80.....
Runs 10.30 @ 134
Old 11-17-2011, 06:18 AM
Good luck.
Makes sense to me. Thanks!
Old 11-17-2011, 11:28 AM
a4ls2goat's Avatar
Runs 10.30 @ 134
damn.. very nice.
whats your mod list? stock block also?
what kinda dyno did you dyno in to net you 720whp?
Old 11-17-2011, 12:19 PM
Yes, stock bottom end too. Procharger, cam, 3.70 gear, dry nitrous shot, 3600 coverter, etc (the standard stuff). Dyno was a DynoJet. 724 is actually calculation based on no nitrous, converter locked, no nitrous unlocked, nitrous unlocked because it wouldn't lock with the nitrous. I expect its accurate with 5 hp.
Old 11-17-2011, 12:36 PM
a4ls2goat's Avatar
damn... thats pretty moving on a G8.. good job man..
how much boost?
Old 11-17-2011, 12:39 PM
10 lbs
Old 11-17-2011, 12:44 PM
a4ls2goat's Avatar
nice, im looking to up my shot to a 250 and hopefully runthe times your running..
im still on a stock 4L65 too... kinda impressed by it..
Old 11-17-2011, 12:58 PM
Yep, stock stuff is tough....until its not Best luck to you with it!
Old 11-17-2011, 03:50 PM
a4ls2goat's Avatar
any pics/other vids of your setup?
Old 11-17-2011, 03:59 PM
Most of my vids are helmet cam stuff. You've seen the best one. There's some vids from ECS on LS1GTO.com in the ECS section
