How big of a shot have you sprayed whith a single plate ??
Old 12-18-2011, 04:08 AM
baezi z06's Avatar
Default How big of a shot have you sprayed whith a single plate ??
Hi guys
how big of an shot have you sprayed threw a single plate and got a way whith it?
i have always heard when you reach the 300 shot mark then a direct port should be vise.
i run nitrousoutlet 92mm plate kit the bigger version whith noids that should support 400hp , deticated fuel cell (high pressure) and NOS launcher
i use HPT - the cell - WB - and plug reading for tuning
i´ve done .078N .035F 62psi BR8´plugs gapped .035 so far on 18° timing
i was thinking for next season of maby working my up to .098 jet or somewhere in that range , is that stupid ?
what have you plate guys done biggest ?
thanks
Baezi
Old 12-18-2011, 09:12 AM
WheelsUp84z's Avatar
I dont know of anyone that has put the full 400 through the N2O Outlet plate, but there is one or two on here in the 300-330 range on that plate. I'd be confident in Dave's stuff to run up to the advertised max output.
Old 12-18-2011, 09:20 AM
Black99TransAm's Avatar
If im correct i have seen 350 range. There is a topic on here talking about it just like this one...
Old 12-18-2011, 10:10 AM
Carter01's Avatar
.93 jet so far which is 300. trying the .99 jet in January. Cam has already ran the .99 jet a few times on a HSW plate.
Major call out - tune to your leanest cylinder always. my number 6 can be perfect but others can be rich. if i didn't tune to number 6 always I would burn mine down....
Old 12-18-2011, 11:59 AM
ShiznityZ28's Avatar
92 jet stage 1, 110 jet stage 2....
Old 12-18-2011, 01:37 PM
camscam02's Avatar
here is a thread from awhile ago
https://ls1tech.com/forums/nitrous-o...sprayed-3.html
I have about 4 runs on a .103 jet... but only because I had to to try and be competitive. Dozens of passes on a .93 and about 10-15 on the .99
Old 12-18-2011, 03:27 PM
baezi z06's Avatar
Thanks for the info guys
what plugs do you run on .93-.103 jets
and what gap?
and what fuel?
again thanks
Baezi
Quick Reply: How big of a shot have you sprayed whith a single plate ??
