Please varify wiring for Cos5
Hi guys i would like to double check my instructions are correct before i start my wiring of cos5
Relay
Terminal 85-goes to my negative/chassi side of nitrous arming switch
30-negative/chassi
86-positive source
87-goes to pin 56 pcm
Thanks
Relay
30-negative/chassi
86-positive source
Thanks
Yes, that is correct. In fact, I wired 86 to my arming switch, positive side and 85 to ground output from window switch. Your going to like COS5.
85-ground output window switch
86-positive side of arming switch
30-chassi ground
87-pin 56
Why did you use ground from your window switch?
Thanks very much
