How to make solenoid bracket hole bigger?
So I'm trying to put a 3/8 bolt through my mounting hole and it's just a little to big. I tried using a drill to drill through and make the hole bigger, but everytime I try it just bends the metal and crimps my bracket up (the metal cheap flimzy ****). Any other good way to make the hole wider?
Use a dremel instead.
Where are you trying to mount the solenoids? There is no bolt I know of on an f-body that will be too big to fit that bracket. Unless you are trying to mount that bracket to the brake caliper or k-member or something
Use the Nitrous Outlet specific bracket so you don't have to use those cheap brackets on the car.
