Max shot on LSXR 102mm intake manifold ?
That is not a intake problem that's a plate problem. I would not go over a 150 shot on a plate or nozzle. It's like trying to get 1000whp out of a remote turbo kit instead of custom manifold setup under the hood. Sure you could do it but it won't be as good or reliable. If your serious about spraying DP kits are worth every penny for peace of mind.
I personaly havn't tried but plenty of people around here have pushed the limits. One has already chimed in this thread. My motor is built for a 350 shot. This year will be the first year out with it and I don't plan to go over 150 on my nozzle. For next year(2013) I hope to have a DP set up and jump to 200-250.
Go **** in the wind and see if it looks like it does in the bathroom. Then try to blow air down a short and long tube. That is the comparison you are making but my demonstration will illistrate much better what we are trying to accomplish.
There are a ton of guys spraying well over 150 shots on plate systems and it has been proven over and over and time again that a ls style intake doesn't distribute well especially on nitrous. Just ask Carter01 and camscam.
The results you and Mike seen between the two different intakes using the same plate technology is a prime example of how intake flow delivery can vary from engine combo to engine combo. On that engine the fast 92 did a better job with the nitrous delivery. Reading plugs is the only way you would have ever known.
This is why I preach that reading the plugs on these higher hp levels is very important. The wirdeband will show an over all airfuel. It would never tell you that you have a cylinder burning hotter than the average reading.
Roger,
Just an FYI, Paul Major ran a rear mount turbo and holds the fastest LS time for anything LS.
