what happens if you smack the rev limiter?
Old 03-17-2004, 11:48 AM
LS1TECH Sponsor
foff667's Avatar
Default what happens if you smack the rev limiter?
say you hit the rev limiter on the 1-2 or 2-3 shift...the stock rev limiter pulls fuel if im not mistaken obviously thats not good for any motor is it a hit or miss thing with an auto whereas youll blow the motor or have people done it time and time again with no major issues? Also would it be wise to try and adjust/upgrade your ignition so it cuts spark instead of fuel?
Thanks
Bill
Old 03-17-2004, 11:56 AM
Slow TA's Avatar
Thanks
Bill
best bet is to get a window switch.
Old 03-17-2004, 07:36 PM
35th SS's Avatar
not good for your motor if you hit it all the time.Ive hit it once or twice on my m6 different times.I agree window switch.
Old 03-17-2004, 08:45 PM
The Guy in MY 99TA's Avatar
I have done it when my old tranny started slipping. I haven't had any problems. U can do the window switch but for my setup I don't want it.
Josh S.
Old 03-17-2004, 08:48 PM
Flamin Raven's Avatar
usually rev limiter = nitrous backfire
It all depends on how hard you lay on the limiter. I've seen people tap the limiter and save it by letting off the juice asap. I've also seen people blow the lid right off and crack the intake.
Don't press your luck and stay off the limiter while spraying. A window switch is a good saftey investment
Old 03-17-2004, 09:09 PM
slow's Avatar
Josh S.
why would you not want a window switch, or RPM activated switch, (for high rpm cutoff only)
I see this responce all the time, but never understand why.
Thanks
Ryan.
Old 03-17-2004, 11:23 PM
Ed Blown Vert's Avatar
Yep, I got one too.
Old 03-18-2004, 12:01 AM
mikey94_95's Avatar
Arrow
Yes, a window switch will work well to keep you out of trouble. Sent you a PM.
Old 03-18-2004, 12:17 AM
1QWIKZ's Avatar
definatrly a window switch. a ignition upgrade will be wasted, stock ignition is an overkill if you ask me.
Old 03-18-2004, 11:49 AM
Chicago Z06's Avatar
window switch....
Old 03-18-2004, 12:35 PM
LS1TECH Sponsor
foff667's Avatar
thanks guys
Old 03-18-2004, 01:01 PM
5 Liter Eater's Avatar
I plan on setting my Harlan @ 2800-5800 but I am concerned that in the event of a missed shift there will still be some nitrous/fuel (wet system) left inside the manifold. I would hate to back off the window switch any more so I guess this is as good as it gets?
