NOS 78MM Plate ?
Old 01-16-2012, 09:04 PM
Its Slo's Avatar
Default NOS 78MM Plate ?
Does anybody have the jet chart or the jet numbers for 150 shot. My older N.O.S book doesn't have it listed.
Old 01-17-2012, 10:50 AM
Nitro Dave's Nitrous Outlet's Avatar
Here you go.
http://www.holley.com/data/Products/.../199R10361.pdf
Old 01-17-2012, 02:32 PM
Its Slo's Avatar
Originally Posted by Nitro Dave's Nitrous Outlet
Thanks I appreciate it
Old 01-18-2012, 02:00 PM
87silverbullet's Avatar
Don't use the plug that NOS recommends in that jetting chart. Get a br6ef or go one step colder and use a br7ef.
Old 01-18-2012, 04:56 PM
98chevyz71's Avatar
sorry to hi jack but how do i adjust the throttle cable after putting the plate on? i have the same NOS plate. after i put it on my throttle is open a lil
Old 01-18-2012, 05:01 PM
There should be a piece that extends the throttle cable bracket With the kit. If not, you need to get that piece
Old 01-18-2012, 05:54 PM
98chevyz71's Avatar
Hmmmm.... Know where i could find one?
Old 01-19-2012, 09:52 AM
Call Holley
Old 01-19-2012, 01:25 PM
Call Holley
I called her but she is in the kitchen making me a sammich. Then we gonna til the sun comes up!
Old 01-20-2012, 01:59 PM
GIMPY02's Avatar
all it is is a piece of 1/8th" thick aluminum plate with 4 holes drilled in it to space everything back to a stock location. pretty easy to do or just readjust the cable and dont worry about it.. i never used the bracket
Old 01-20-2012, 04:42 PM
Chris@NitroDaves
Guest
Posts: n/a
Old 01-20-2012, 08:08 PM
Its Slo's Avatar
I elongated the bolt holes a little. I'll have to figure something out for my cruise cable though,mine has no adjustment that I've seen
Quick Reply: NOS 78MM Plate ?
