TNT F2 Jetting Question
Old 01-30-2012, 02:44 PM
frankmarroquin's Avatar
Default TNT F2 Jetting Question
What's the proper way to jet the F2 since it has two Nozzles? I am aiming for a 200... Thanks in advance
Old 02-11-2012, 09:23 AM
dnkynrbk's Avatar
If you can find the jetting chart you just put the same size fuel jets on both sides and same n20. Just dont use other companys jets in the TNT kit. I used to have one of these back in the day they hit hard lol. They jetting was always on when I had my kit.
Old 02-11-2012, 07:09 PM
magnum-gto's Avatar
I just pulled my old card for the TNT Force 2 jetting:
200hp reads 51 N2O and 28 fuel.
We found that the TNT jetting was always on the rich side.
Those numbers can be off quite a lot depending on the fuel and bottle pressures you plan to run.
Old 02-12-2012, 12:05 PM
dnkynrbk's Avatar
Just rember to have to repalce your stock fuel pump and run good fuel and you should be good ohh and retard the timing and the right plugs
Quick Reply: TNT F2 Jetting Question
