Nx Wiring...help!
Nx Wiring...help!
OK, I'm a little confused. I'm no wiring genius, but I have the wiring diagram for the NX wet kit, and the separate one for the window switch. Well, currently, I am going to wire it up as follows. Please tell me if this is wrong.
OK, first the arming switch: Ground, Hot to switched, other to relay.
Relay: Powered by battery, not switched source? Grounded on frame. One wire powers noids.
Window Switch: Powered by switched source, grounded to frame, one wire to tach, last wire grounds noids for activation? Used 16 Ga. wire except for wire going to BATT from relay. It is 12ga. Someone please tell me if this is correct!
