what should i run on 150 shot
Old 02-05-2012, 09:40 PM
loosews6's Avatar
Default what should i run on 150 shot
i have a 99 ws6 with slp lid, 9" with 4.11s,ls6 intake, long tubes, 3" all the way out to maggies,3400 rev maxx converter,tune - suspension i have sphon torque arm and lower adj control arms.... i run 1/8th mile only, right now n/a i run a 8.0 with a 1.85 60ft spin out the hole with mt 275/60/15 drag radials on 15x10s pro stars... im going to a full slick and i bought a tnt f2 kit what will i run if a get my 60ft down and my n/a time to 7.8.....with a tnt 150 shot on full slick...
Old 02-06-2012, 10:34 AM
TA1364's Avatar
You are spinning with a 275/60 and just bolt ons? I'd figure that out before even trying to spray it. Should run bottom 7s at least.
Old 02-06-2012, 11:50 AM
01SOMZ28's Avatar
When i was just bolt-ons and stalled, i went from a 12.7 to 11.3 in the 1/4 on a 150 shot.
Old 02-06-2012, 04:10 PM
89camaro's Avatar
should run between 6.80's to 7.0's
Old 02-06-2012, 05:11 PM
Captain Double Post
BOBS99SS's Avatar
yeah you should be able to hook with no issues at all, you sure those are drs lol
Old 02-06-2012, 05:18 PM
soundengineer's Avatar
guys are running 1/8th mile 4's and 5's with a 275 drag radial...
sounds like you need suspension work more than anything else
your MPH will give you a good indication of how fast you should be able to run once you get it to hook up off the line
Old 02-06-2012, 07:46 PM
loosews6's Avatar
yea...they are a little dry rotted...but track sucked i had them on 20psi
Old 02-06-2012, 07:48 PM
Dont Blame it on track prep...
Need Suspension Work, and Tire Pressure was too High..
Old 02-06-2012, 07:56 PM
loosews6's Avatar
ok well what do i need tell me please............................????????????
Old 02-06-2012, 07:59 PM
tell us your suspension setup and your motor/trans/rear setup
are you lowered or stock height?
explain your burnout procedure..
need more details
Old 02-06-2012, 08:05 PM
loosews6's Avatar
need more details
moser 9" with 33 spline axles,4.11s ,1350 yoke,sphon torque arm tunnel mount with loop,adj rear control arms, stock height, no rear sway bar,stock phb, bullsh** air shock with line cut....i getting the Competition Engineering shocks with week..and adj phb.. burnout 1st about 4500rpm them shift into secound from 2-3 secound when round out...motor 99 ws6 with slp lid, ,ls6 intake, long tubes, 3" all the way out to maggies,3400 rev maxx converter,tune
Old 02-06-2012, 08:13 PM
you need a rear sway bar bad....
its extremely important for being able to hook up off the line...even more important to be able to launch straight and even
without it... really not a lot of hope of getting a good launch
I suggest the BMR Extreme Duty anti-roll bar, but feel free to get whatever fits your budget best.
you would benefit from an adjustable panhard, but it just keeps the rear centered better and keeps it from walking around while in motion.
does your 9" have LCA relocation brackets on it?
you need them to be able to get LCA geometry correct...
adjustable shocks for front and rear will help as well
prefer something like a Qa1, but the comp engineering shock do pretty dam good usually till you are down in the 9's
what tranmission? I can only guess at an M6 with seeing the 4.11
which makes it a little tougher to hook at the line unless you get the suspension correct or unless you are good at slipping the clutch and not just doing a 5k dump..LOL
Old 02-06-2012, 08:45 PM
loosews6's Avatar
ok 4l65e with 3400 rev maxx converter
Old 02-06-2012, 08:51 PM
yeah.. with an auto... hooking up should not be that much of a challenge...
that leads to suspension issues...
get that stuff sorted out, and then start dropping the tire pressure some...20 is a wee bit too much to get any good traction off the line...
start around 17 with those and work downwards till it hooks up best...
I'd be willing to bet around 15 or 16 will probably be the magic number..might even get downwards of 14 if its the older compound...
Old 02-06-2012, 09:50 PM
loosews6's Avatar
ok man thanks alot im going to try 15 and go from there...
Old 02-15-2012, 01:08 PM
74novacustom's Avatar
Dont go crazy with the burnout on the DRs, They like to be hot but you can overdue it. Just hold it in first for a couple seconds and getem smoking and your good.
Old 02-15-2012, 01:15 PM
I Ran 1180s with a 88camaro, Stock sb400 rv cam from suburban, no stall, 273 gears, open diff. 175hp shot on DRs.
I brought my own trac bite. had a buddy poor a little in front of each tire, i did one little burn out with one tire, rolled two feet then did the other tire. then squeezed off the line!!. 11.84! 118mph. all motor it ran 14.5!!!!
Old 02-15-2012, 06:22 PM
THIS!!.. .sort of...
Tire speed helps with getting heat before smoke..
you can get smoke at a pretty low speed and not get them hot enough..
what you want to do is get enough tire speed to get it hot, but not make a lot of smoke
for me, being an automatic, its a lot easier... I just set the line lock and mash my foot... I see 100mph usually in a burn out and as soon as it starts to smoke I let off the line lock and get out of the gas.
its a little tougher in a manual car... need to do the burnout in 2nd gear if possible.
Old 02-15-2012, 06:54 PM
Fbodyjunkie06's Avatar
Are you serious that you don't have a rear sway bar?
How does that thing drive on the street let alone launch at the track in a straight line?
Adjustable shocks will do you more good than anything else at this point.
I'd really try to get a set of QA1 R series single adjustable shocks over the comp engineering shocks. Even though QA1 isn't considered top of the line it's a better product than those.
Old 02-15-2012, 08:12 PM
loosews6's Avatar
no sway bar but a panhard bar yes...... and get the qa1's for the rear?
