for those spraying out thehole
Old 02-22-2012, 06:45 PM
98LS1driver's Avatar
Default for those spraying out thehole
Getting a fully built 4l60e for my 01 ss and looking to squeeze it 150 out the.hole or as soonas possible after launch with 315-35-17 et streets what would.be the best method to start with 1/8 th mile track my kithas window switch and ill.be running a single nozzel stock rear with3.42s using a yank ss3200 also
Old 02-22-2012, 06:51 PM
sweet99ss's Avatar
Who is building your 4l60e?
Old 02-22-2012, 07:17 PM
94dragbird's Avatar
I sprayed 150 out of the hole with a yank ss3600 and a 10 bolt with 373s
Old 02-22-2012, 09:10 PM
Kooks trans in.cowpens sc
Old 02-22-2012, 09:12 PM
Was thinking about having it On a button. And going to spray after it hooks up
Old 02-22-2012, 10:08 PM
VinnieV02TA's Avatar
i have the same set up but with 373 gears and 3600 stall and with those tires i can not launch from the hole without spinning. I dont have a window switch right now but i end up turning the nitrous on about about 60 feet or less and it works best for me.
Old 02-23-2012, 09:58 AM
Should I leave off idle or stall it a little
Old 02-24-2012, 07:27 AM
WhitePhoenix99's Avatar
Best thing you can do is try both and see what works best for your setup
Old 02-24-2012, 10:30 AM
zracer323's Avatar
It's going to take some trial and error. What are you running suspension wise, adjustable? I would start with a 75 shot on a button and work your way up. You may have some trouble with those tires with such a small sidewall.
Old 02-24-2012, 10:40 AM
TA1364's Avatar
Get the system on a window switch and arm button. It will be a lot easier to control and more consistant. Spraying out of the hole on those wheels and tires probably wont hook.
Old 02-24-2012, 12:24 PM
Same thing I was thinking especially since now I'm going back m6 stage 2 rebuilt t56 going to put on a microswitch with the window switch and see how it goes starting low with 100 wet
Old 02-24-2012, 12:30 PM
camaroboy869592's Avatar
If it hooks and leaves real hard your on borrowed time with the stock rearend and drive shaft
Old 02-24-2012, 05:39 PM
brodystruck's Avatar
I ran a msd window switch and 28x10.50x15 slicks on my old silvy. It hooked out of the hole on 150 shots...
Built trans or not, I'd worry about eventual failure if it hooks...
Old 02-24-2012, 09:49 PM
94dragbird's Avatar
I had mine on a wot switch. With the window set at 2800. Sprayed 150 out of the hole on 28x10-15s pulling the left front. It lived but I switched to an s60 before the 10 bolt broke
Old 02-25-2012, 05:32 AM
soundengineer's Avatar
Originally Posted by 98LS1driver
Getting a fully built 4l60e for my 01 ss and looking to squeeze it 150 out the.hole or as soon as possible after launch with 315-35-17 et streets what would.be the best method to start with 1/8 th mile track my kithas window switch and ill.be running a single nozzle stock rear with3.42s using a yank ss3200 also
your best method would be to get rid of those rims and tires and get something with a smaller rim and a bigger sidewall for the track.....
