Talked to old school racer about n2o & timing,do u think he is right? Need exp. guys
I talked to an old school racer and we got on the subject of nitrous and timing. We talked about making sure you tune the motor to its best power and then when spraying he started to say that you don't need to pull no timing on the 1st 100 shot of nitrous and you only need to pull the rule of thumb (2 for every 50) after that.
I like to be on the conservative side of everything and in this case I disagreed with him. I might not pull the whole 4 degrees out but I'm not going to just run motor timing on the 1st 100 of a 200shot and then only pull 4 degrees total.
What do you guys think?
The only rule is to pull more than you think it needs and work your way up.
No big changes and only change 1 thing at a time so you can see what effect it had.
It wants what it wants every combo will be a littl different, the plugs will tell you which direction to go in.
This is a pump gas motor with c16 in the cell for nitrous SBC setup
Im still looking for the spread sheet that says X amount of octain equals x amount of advance jetting.
With a nitrous motor to much timing is usualy the main reason why someone hurts a motor.
