You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join LS1Tech.com today!
I go to Vegas for the weekend and live it up and come back to all this nonsense! haha congrats bud! not too shabby and when are you guys gonna learn to keep the front end of these cars tight?? y'all crazy
Damn front compression was a little too loose and I only had 32psi in the front tires=hard landing after 4'x80' power wheelie lol!
Check it out this was 2 passes before my new PB where it wanted to spin and went 6.270@109.87 which is damn well 110...
And then here is the 1.31 60', wheelie pass. I thought it was longer more like 100'+ but after talking to some people about where the SYA's landed in the track it was just past the 60'. You can see though I lost everything I gained at the 60' to the 330' and then made it back up on the big end.
__________________ Tick Peformance, Nitrous Express, Menscer Motorsports, FTI, Madman Suspension, Holeshot Wheels
6.10@113 1.29 60' Video:http://s1105.photobucket.com/albums/...t=IMG_0411.mp4
Martin Smallwood-Tech/Customer Service/Sales
Tick Performance of Mount Airy, NC - Specializing in GM LSx Performance
336.719.0599
not too bad, thats exactly what mine ran on the 62N with stock heads when we first started this setup like 2.5 years ago. 1.39 6.279 110.17 9.92 137.7
I don't like ours to wheel stand what so ever. usually 6-8 from full loose. we have 12 clicks
Is that what you run extension wise and that's on a slick too correct? I have 40 clicks on extension and 24 on compression lol. I think I ended up 20 on extension in the front, and 12-13 in the rear. Track was loose.
I am thinking about putting my LCA's in the lowest hole I have instead of the middle and then lowering the rear end of the car a good bit with the adjustment collar on the afco's, and since the front's are about to wear out soon I want to go to a 26 instead of the 27 I run now and lower the front with it to keep it's current slight rake.
Then again I have heard the more separation I create the more compression setting I need and I am completely maxed out on my compression setting.
I may need to send my shocks in for a re-valve.
336.719.0599
Yup just the Qa1s on the front, but DA Madman valved Afcos on the rear! Worth every penny
Thats front extension, rear is a completely different settings depending on conditions and yes on a slick.
Congrats on your runs Fbodyjunkie.. I think I discovered the problem in ours, new cam should be at the shop Friday. Can't wait to see what we can get done once the engine will go over 6,000
*fingerscrossed*
__________________
Legend Racing
1998 Trans Am coming soon
Home of the quickest and fastest stock cube nitrous powered LS1.
8.87@153 1.25 60'
*fingerscrossed*
Thank you!
I need to start a thread and put some pictures of the car up as it sits now. I don't think anyone has seen it in a full still shot with the new revolvers, front hole shot hub caps, the nitrous outlet window banner and under the hood since I installed the plate.
If anyone is interested in the rear suspension and the front end work I'll take some pictures of that too. I just haven't done it because I didn't want to feel like a picture/attention ***** lol.
336.719.0599
Im assuming you're talking about the rears, but they are ordered from Madman and Co Racing, they are sponsor here
Yes the rears, thanks. ill check them out.
Thank you!
Me three! Our cars are very similar. My dad told me not to paint the VFN hood and leave it black. It looked good on silver but of course I didn't listen. You posted them picutes yet?
__________________ 2002 Silver Camaro Z28
416 Iron Block, AFR, Solid Roller, Super Victor, Accufab 4500, TH400, 9" Currie.
Ill be out June 9th but with street tires on, not sure when we will have the 28's on to run the 1/4 probably a couple months at the least. Im expecting Ill have a new number to chase down when that time comes, I don't see my .36 holding up
