150 shot questions - LS1TECH
150 shot questions
Thread Tools Search this Thread
Old 03-19-2012, 06:37 PM   #1
Blastin's Avatar
Default 150 shot questions
Hey guys i have been running my 100 shot for a year now and like every new season need to go a lil faster. I plan to drop a fuel pump and straight 110 and see she does. I would like to get some more advice. Current mod are lid, smooth bellow ,descrean maf, cut off muffler and 100 on the fogger. Best time is 12.16 @114 1.6 60ft spun for a sec then hooked on nt01s spraying out the hole.
I am also wondering how the stock a4s are holding up on a 150 hit with a ten bolt
Blastin is offline   Reply With Quote
Old 03-19-2012, 11:52 PM   #2
LS1TECH & TRUCK Sponsor
It will hold for a while but eventually the torque will take it toll on the stock transmission. The stock rear end is a hit or miss once you bolt some sticky tires to it and let it bite on the spray.
Dave
Nitro Dave's Nitrous Outlet is offline   Reply With Quote
Old 03-20-2012, 08:50 AM   #3
GIMPY02's Avatar
Quote:
Dave
my stock 70k 4lshitty hasnt broke yet... just ask larry lol been sprayin the car for going on 3yrs now. havent even changed the fluid since i put the converter in it and had it at speed inc yrs ago.. rear end is a hit or miss for sure.. im still running the stock 10bolt but i always go underneath and re torque the pinion and thats been fine so far.
GIMPY02 is offline   Reply With Quote
Old 03-20-2012, 11:30 AM   #4
Thats awesome. From My experience once the stock one goes out and a trany shop rebuilds it they never hold for as long as the stock one did.
Dave
Old 03-20-2012, 11:33 AM   #5
TA1364's Avatar
I dont see the need to run 110. Car should go close to 120 mph.
TA1364 is offline   Reply With Quote
Old 03-20-2012, 02:52 PM   #6
GIMPY02's Avatar
Dave
yup i agree.. as long as u put good fluid in it and a big cooler ur fine... but then again anything can happen.. they can go for yrs b4 they brake or a week... just never know
Old 03-20-2012, 08:39 PM   #7
Captain Double Post
Add a cam and spray the 150, you will have the power to run some killer times, but that's if you can put it down,
BOBS99SS is offline   Reply With Quote
Old 03-21-2012, 07:13 PM   #8
Blastin's Avatar
My trans is stock with a cooler, and seems to be fine for now the ten has held up pretty good a few guys here have gone through 3.
Thanks Dave
@ta1364 you spray a 150 on 91????
@GIMPY02 what brand of fluid do you call good?
Old 03-21-2012, 07:32 PM   #9
Blastin's Avatar
Another question i have is, is it really worth going to a plate over s fogger i hear people say it hits harder but will you see drop in et on the same shot?
Also i can only seem to run my best times with my buddy zex bottle over my nos bottle not sure why?
Old 03-21-2012, 07:43 PM   #10
David Q's Avatar
Once you get the car to hook on sticky tires, the stock trans won't last long. Mine only lasted about 10 bottles with 68000 miles on it. I have always run synthetic fluid and an external cooler. 93 octane fuel will be fine for a 150 shot. Maybe your buddies bottle has a better valve and pickup tube compared to your NOS bottle.
David Q is offline   Reply With Quote
Old 03-21-2012, 08:13 PM   #11
sweet99ss's Avatar
Dave
I beleive that is because most local little tranny shops do **** work and put in crapy universal clutches that could be for 200 hp cars. The only place to get transmissions built for these cars is sponsors on here like FLT or Performabuilt imo. Or atleast a well known/proven performance tranny shop that knows how to build a tranny for high hp.
sweet99ss is online now   Reply With Quote
Old 03-21-2012, 11:08 PM   #12
TA1364's Avatar
I have sprayed 175 and 200 on 93, sprayed 150 with 93 many times. I run 8 degrees of timing out and br7ef plug gapped .032.
Car has 106000 miles on it, transmission has a shift kit but other wise stock, 10 bolt is bone stock. I have have definatly been lucky.
Old 03-22-2012, 09:13 PM   #13
Blastin's Avatar
Ok thanks for all your help
Old 03-25-2012, 01:24 PM   #14
Johnnystock's Avatar
I spray 150 with 91..
Johnnystock is offline   Reply With Quote
Tags
ls1tech, stock, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
