Speed density tune with nitrous??
Old 03-20-2012, 04:03 PM
n2ols1cam's Avatar
Default Speed density tune with nitrous??
Hey guys I have a forged ls1 with ported 243 heads and a ms3 cam, I will be spraying a 300 shot at the car sometime this year. I need to get my car retuned and I was wondering if I should do a speed density tune. Would it help for nitrous? What would be the benefits of going with a speed density tune? Thanks guys!
Old 03-21-2012, 11:30 AM
soundengineer's Avatar
No power difference in speed density or a MAF tune....
2 different ways to get to the same end result.
a MAF is better at Day to Day compensation and will be more consistent at WOT
but SD has benefits too...it tends to have a crisper throttle response as you are telling it the fuel instead of the pcm looking at airflow and then calculating how much fuel it needs
unless you use a HP Tuners custom OS, you will be using the secondary VE table without the MAF(on 98-00 cars) and you will be using the low octane spark table without the MAF(all cars)
so without a Custom OS, staying with the MAF has benefits over SD.
wet shot or dry shot really makes no difference on either...
Old 03-21-2012, 11:43 AM
n2ols1cam's Avatar
Thank you for the response. so a SD tune wont hurt my car's performance on nitrous?
Old 03-21-2012, 11:45 AM
nope...not one bit...
I'm a perfect example...
I cant use a MAF due to my extreme setup and I have an aftermarket pcm doing SD....
dual direct port dry shot....and not a small one
Old 03-21-2012, 11:56 AM
n2ols1cam's Avatar
ok cool. i have to get my car retuned so i think going to go speed density. ive heard that the car will run a little better and have better driveablity. and plus i want to get rid of my restrictive maf. a stock pcm can handle a SD tune just fine right?
Old 03-21-2012, 12:03 PM
the MAF is usually not a restriction unless you still have a stock one with a bigger TB
once you upgrade the TB you should upgrade your MAF to match
they make 100mm MAF's and 104mm Lid's
the car will run the same in SD or using a MAF... its all about how good yoru tuner is...
driveability will be identical either way if tuned properly.
and yes...the stock pcm can handle a good and proper SD tune
Old 03-21-2012, 01:09 PM
n2ols1cam's Avatar
as of right now i have a slp lid with a stock maf and a 92/92 setup. so i was going to run a ftp 98mm with no maf. would you recommend going SD or go with buying a bigger maf?
Quick Reply: Speed density tune with nitrous??
