Did a Little Wiring on a buddy's G8..
Old 03-21-2012, 11:08 AM
n20kid's Avatar
Default Did a Little Wiring on a buddy's G8..
So just finished up some wiring on a buddy's G8, to sum it up we did the N2o Outlet G8 specific plate kit which is a killer piece and bar none the nicest out there! the owner is in a wheel chair and has to have everything mounted with ease of access.. So, with that being said i wanted to make sure everything was "Fail Safe" and easy to get to from the driver's seat. The Main feed line was routed up thew the floor of the passenger rear floor board where the bottle was mounted and out side threw the frame rail and wrapped in a high temp insulation for heat purposes.. Everything on the install was soldered and heat shrinked, and if a connector was used it was a marine grade shrink connector.. Then everything was routed in Xtreme high temp spark plug wire insulation.. Enjoy!
Old 03-21-2012, 12:29 PM
David Q's Avatar
Looks good. It takes alot of time to solder and heatshrink every connection, but the end result is amazing. There is alot of electrical connections in a nitrous setup when done right. Good work.
Old 03-21-2012, 01:40 PM
1990LSx's Avatar
Race car!
Old 03-21-2012, 02:05 PM
n20kid's Avatar
Originally Posted by 1990LSx
Race car!
Pot calling the Kettle BLACK....
Old 03-22-2012, 09:18 PM
Nitro Dave's Nitrous Outlet's Avatar
Nice looking work. Your going to have a nice install there.
Dave
