LT1 Intake Max Shot
Old 03-22-2012, 08:54 AM
warriorcustoms's Avatar
Default LT1 Intake Max Shot
Ok I figured Id post my question & see what the gurus say!!! Whats the max wet shot a ported LT1 intake will flow (through a NX maf end) Ive been told 200 & 400! lol SO anyone sprayin the **** out of a ported intake through maf ends , dual nozzles or plates feel free to chime in. Search = 0 results Also Im not askin about a Direct Port lol Thatll need to wait till after the whole cars done lol Ive got 2 NX kits
Old 03-22-2012, 09:31 AM
Tony Shepherd's Avatar
Got your PM. Was about to reply to it.
The ported stock intake can take as much as you can throw at it. It's the head flow, cam profile, and exhaust restrictions that is the limiting factor.
edited...see below about a MAF end.
Old 03-22-2012, 12:10 PM
Thats want I needed to hear. Just figured you were super busy. Reason Im asking is a buddy was buildin a 70s Furd 302 max effort, But he got scared thinkin im runnin a 396 bbc lol So he went & got a 429 Ford motor & if his family gives him what he wants, He will have an old school 6-71 blower on that bitch. LoL My combo will be all forged 4340 with ported 200cc Pro 1 heads. headers will be kooks or obx with a 3.5in Ypipe & 4in mufflex single dual 3 out set up Oh & my throttle body is a 58mm tpis. They talked me out of a monoblade lol Custom cam 24x/25x @ .05 & .6xx lift Built 4L60E with around a 3200 stall & 3.73 or 4.10 gears. Suspension will be UMI adjustable stuff with the torque arm relocated Ive got all my nitrous stuff except a few safety things & the twin 255 walbros Gotta smoke them fords lol & I wanna make that old ford look silly LoL
Old 03-22-2012, 09:17 PM
Did you edit your original post? That or I mis-read it. I don't remember seeing anything said about a NX MAF end kit If your using a NX MAF end kit I would limit that to a 200 shot. With a plate you can go up to 300 shot if you really know how to read plugs and tune. If you are not an experienced nitrous tuner, stick to a 200 shot or less.
Old 03-23-2012, 08:36 AM
Guess I will get a Direct Port plumbing kit after my cars painted & rollin under its own power I did ask about maf ends ,plates & dual nozzles. The direct port will do as much as I need @ 300 or 400. LoL Most of the time itll be rollin with 200. Just want to make a ford look stupid.
Old 03-23-2012, 10:06 AM
Nitro Dave's Nitrous Outlet's Avatar
For the power level you are focusing on I would go ahead and do a directport and be done with it.
If a directport is not an option I would use our LT1 efi plate. It will do a much better job saturating the air intake charge than the Mass air dicharge ends or a nozzle in the airstream. The mass air kit is nothing more than there shark nozzle machined into a mass air end.
Even using our plate as you move up from 200 to 300 hp you better be on your A game reading the spark plugs. The plugs will tell you when you have reached a point of poor distribution to the cylinders and which cylinders are your hot cylinders. Every engine is different.
Old 03-23-2012, 10:31 AM
One thing to also note, on a stock LT1 intake, the #8 intake runner is aligned with the back wall of the intake which directs more air/nitrous to that particular cylinder. Results in leaner condition compared to the other cylinders. If you do a direct port, you will not have to worry about this as much compared to using a nozzle or plate setup.
Old 03-24-2012, 11:32 PM
Direct port will be after the cars finished lol Ive gotta finish paint & the drivetrain
Quick Reply: LT1 Intake Max Shot
