Effects from NGK loose plug tips??? - LS1TECH
Thread Tools Search this Thread
Old 03-25-2012, 05:30 PM   #1
9 Second Club/Nitrous Mod
shortdog's Avatar
Question Effects from NGK loose plug tips???
Like the title states:
Yesterday, I sprayed at the track and it surged on the big end for the first time in years, but ran great N/A afterwards. A/F averaged 12.0 the whole nitrous pass, so being rich wasn't an issue.
Today, I pulled the ngk plugs and two were finger loose. I've tightened them with some pliers prior to installing them, but a few have worked themselves loose again. This is not the first time this has happened. Just wondering if the loose plug tips could be the culprit.
This is becoming a pita.. I may just go with some Autolite AR472s and ditch the NGK brand completely.
shortdog is offline   Reply With Quote
Old 03-25-2012, 05:52 PM   #2
INTENESS's Avatar
They are a pain to deal with those threaded ends on the ngk's,i really snug em tight and they haven't worked losse.There a much easier plug to read then the autolites thats why I run'em.
INTENESS is offline   Reply With Quote
Old 03-25-2012, 07:35 PM   #3
Carter01's Avatar
I don't think the loose tips would cause that problem. As much fire that is coming through the coil on plug setup would easily over compensate for the loose tip. I would be looking elsewhere, just my opinion.
Carter01 is offline   Reply With Quote
Old 03-25-2012, 08:44 PM   #4
6 & 8 Second Club
mrdragster1970's Avatar
I don't know what plug you guys use, but my plug has 2 models.
1 has a solid tip & one has screw on.
Everything else is the same, but for whatever reason, they make both styles??
mrdragster1970 is offline   Reply With Quote
Old 03-26-2012, 08:14 AM   #5
shortdog's Avatar
I would think a loose tip could cause a misfire, or keep the car from running it's full potential. What's really mind boggling is not knowing if they came loose before, or after the passes.
Old 03-26-2012, 02:40 PM   #6
I know the new seadoos run the tip removed. I have never had a problem with the tip backing off.
Z284U2TRY is offline   Reply With Quote
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
