Filling a 10lb bottle with a 10lb bottle?
Old 03-25-2004, 03:25 PM
8 Sec Tuner
Mike TexaSS's Avatar
Default Filling a 10lb bottle with a 10lb bottle?
Right now i have 2 bottles with about 6lbs in each one. Any way to use one to fill the other w/o a pump?
Any old hot rod tricks?
Old 03-25-2004, 03:32 PM
C4VetteLS1's Avatar
Freeze one and put the other out in the sun for a little while. It should transfer.
Old 03-25-2004, 03:40 PM
8 Sec Tuner
I freeze the one i want to fill right?
If i use my bottle heater and heat the other to 1050psi or so it should transfer fairly easily?
Old 03-25-2004, 04:11 PM
mike02ss's Avatar
Yes freeze the one you want to fill.
Old 03-25-2004, 11:03 PM
taqwache's Avatar
that will be the best way to do it without a pump. just make sure that you have both bottles standing up for best results.
Old 03-26-2004, 02:05 AM
DONAIMIAN's Avatar
what size is the line on thoes bottles, I have a pump and will do it for free.
