spray bar vs direct port nos
Old 04-11-2012, 02:39 AM
mr chevy's Avatar
Default spray bar vs direct port nos
witch one of these is better for a 300 shot
Old 04-11-2012, 08:47 AM
ATVracr's Avatar
Dp ..
Old 04-11-2012, 09:20 AM
dreww's Avatar
Everything I've read says for 200hp+ direct is the ticket. If I ever step up to a motor built for it, ill run direct when I hit 200 pill
Old 04-11-2012, 09:22 AM
Neal@NitrousOutlet's Avatar
On a 300 a direct port would be great being that every cylinder would have its own nozzle meaning that every cylinder would be getting equal amounts of fuel and nitrous in precise amounts.
A properly set up spray bar could do a 300 jet as well but there is more room that it could be a little off for perfect cylinder distribution.
Old 04-11-2012, 10:24 AM
6 & 8 Second Club
mrdragster1970's Avatar
With 300, I would also use DP. I really prefer having control over each hole.
Even the best intakes can have subtle differences that can be an issue the bigger you get.
Even on my top quality tunnel rams, we find differences hole to hole we need to adjust for.
Old 04-11-2012, 10:56 AM
87silverbullet's Avatar
You can run a 200 now. Many guys running 200 on a plate. 225-250 is when you need to look towards a DP unless you are a very experienced nitrous tuner
Old 04-11-2012, 12:28 PM
N2OBaby's Avatar
Good to know that is something I haven't read in the mags.
Old 04-11-2012, 06:37 PM
GIMPY02's Avatar
Dp all the way.. but it also depends on ur budget. Dp aren't cheap by any means especially when it comes to buying jets to spray more at it or just to fine tune it. Instead of just buying 2 jets ur now buying 16. 8 for fuel and 8 for nitrous. Spray bars or a plate setup have come along ways. So either way ur fine just keep an eye on ur plugs and take baby steps on how much u spray u will be fine
Quick Reply: spray bar vs direct port nos
