n/a+spray+e85??? - LS1TECH
n/a+spray+e85???
Thread Tools Search this Thread
Old 04-12-2012, 11:46 AM   #1
01SOMSS!'s Avatar
Default n/a+spray+e85???
Would I benefit from swapping to e85 on my new built? Heads,ms3+zex wet 150 shot. Or would it make more sense to just run 100oct vp race fuel?
01SOMSS! is offline   Reply With Quote
Old 04-13-2012, 10:33 AM   #2
LS1Tech Premium Sponsor
Some things to think about, and depending on what fuel you are running now. Are you running pump gas currently? If so you could run more timing with the e85 and could make more power NA and would be safer with the nitrous.
Also something to take into account. Do you have the fuel pump and injectors to run E85 without running out of fuel? With the increased need on pumps and injectors to run e85 make sure if you don't have these that you will probably need to get them to even run NA. Also you have to have more pump for e85 with that wet kit as well.
If Daily driven is E85 readily available around where you live and if not do you have a tuning device to be able to change over tunes if you cant find a e85 gas station.
Converting to E85 can have a great power advantage if you have the ability to run it. If you do then go for it. If not running 100 is a good option as well.
Neal@NitrousOutlet is offline   Reply With Quote
Old 04-13-2012, 06:29 PM   #3
warriorcustoms's Avatar
I was gonna run E85 till I realized I would have to drive 40 + miles 1 way to fill up the T/A So itll get 93 Octane & a really good tune for my 12.5 to one build
warriorcustoms is offline   Reply With Quote
Old 04-18-2012, 06:00 PM   #4
armyboyatc's Avatar
It boils down to the convienence factor. I have a pump a few miles away from me so I am going to run E85 and a Vic Junior spray barred intake from Nitrous Outlet. From what I understand the E85 is going to net more power all day than the 93 and it costs less than 93.
Before we had an E85 pump here, some turbo boys would by 55 gal drums of it.
armyboyatc is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
What Would Be A Good E85 Pump To Run Jose Scott Fueling & Injection 2 01-31-2017 09:40 PM
E85 cam Catfishman Generation III Internal Engine 9 08-30-2016 09:59 PM
E85 NSTY Z LT1-LT4 Modifications 14 08-19-2013 02:52 PM
Regret going E85?? or not going?? Burken01 Forced Induction 43 04-09-2012 07:58 PM
E85 Guru... FakeSnake Fueling & Injection 24 05-13-2011 11:27 AM
Tags
93, advantage, e85, fuel, ls1tech, na, nitrous, oxide, power, pumps, race, run, running, timing, tune
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
