Nitrous activation switch - LS1TECH
Thread Tools Search this Thread
Old 05-05-2012, 04:03 PM   #1
1slowbusa's Avatar
Default Nitrous activation switch
What nitrous activation switch can i use. I am currently installing a fast 102 intake and throttle body with a 102 nitrous plate between the 2. What can i use for the wide open throttle switch?
1slowbusa is offline   Reply With Quote
Old 05-06-2012, 10:36 AM   #2
5o2slow's Avatar
check this one out from dynatune, it activates i think 3 different ways if am not mistaken. Am using one
http://www.dynotunenitrous.com/store...?idproduct=194
5o2slow is offline   Reply With Quote
Old 05-07-2012, 11:08 AM   #3
LS1Tech Premium Sponsor
Quote:
You have a couple of options. You can use a Mirco Switch, a Window Switch, or Progressive
All of the above will get you spraying. The links will let you see and read about the differences in the 3. Hope this helps
Neal@NitrousOutlet is offline   Reply With Quote
Old 05-09-2012, 10:51 PM   #4
warriorcustoms's Avatar
I've got a new zex window switch with tps activation Id sell it came with my carbon fiber kit but i dont need it since im runnin 2 stages & have a nitrous outlet dual window switch
warriorcustoms is offline   Reply With Quote
Tags
102, activate, activation, body, difference, fast, ls1, micro, nitrous, open, switch, throttle, tps, wide
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
